Re: 706 engines
Posted by The tractor vet on May 10, 2011 at 22:54:21 from (76.212.227.102):
In Reply to: Re: 706 engines posted by Larry B 1486 on May 10, 2011 at 19:46:25:
Don't know we do not have that here But keep in mind that it takes more alkihol to make the same pony power . From what little i have played with Alkihol you can melt one down or ya can throw the crank out on the ground and lift the head clean off BTDT. Did a little playen with the stuff in a blowen 487 Donavin did a lot of fixen on it in all nighters to make it go the next day . All i know about E85 is what i have heard and that is hearsay.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
