Re: Farmall A governor control question
Posted by Jim Becker on May 11, 2011 at 16:05:41 from (173.57.144.251):
In Reply to: Farmall A governor control question posted by kopeck on May 11, 2011 at 09:57:58:
Wear to the shaft/housing where the arm goes into the governor can have a lot of effect on where the control lever ends up. Setting of the high idle stop screw does as well. I don't know if that will explain what you are seeing.
