Re: 706 engines
Posted by FC Andy on May 11, 2011 at 17:19:34 from (74.126.84.52):
In Reply to: Re: 706 engines posted by Larry B 1486 on May 10, 2011 at 19:46:25:
Well, I can tell you that a fella shows up at the local plow day with an oliver 88 running on e-85. I don't know if he's worked it burning ethanol. I do know I've ran it through a few lawnmowers in the past, only needed to give it a 1/4 turn more fuel, ran great. I've got an '06 chevy half ton that has only burned maybe a half dozen tanks of gas in almost 60,000 miles. Exhaust pipe is clean, truck runs great. Even the oil stays a little cleaner. I'd try e-85 in my old M if I still had it. Might try it in My old Cub Cadet again now that fuel is expensive again... -Andy
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
