Posted by D Slater on May 11, 2011 at 18:23:06 from (184.15.43.86):
In Reply to: Int. 300 starter posted by Pastor Brad on May 11, 2011 at 16:45:22:
If you unhook all power and the starter stays engaged with the starter gears? You have a bad gear on the flywheel or the starter is not fixed correct or has the wrong part or parts installed.
Should have asked does the tractor start and the starter gears stay engaged or engine doesn't start?
This post was edited by D Slater at 18:25:05 05/11/11.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
