Re: restoring farmall 100
Posted by couv on May 11, 2011 at 20:28:50 from (209.33.2.30):
In Reply to: restoring farmall 100 posted by michael greenhaw on May 11, 2011 at 09:01:09:
kalscheur at 6087983371 or Bates 8002482955
cap screw is part # 362593r91, nut with the metal clip to hold it in place 362594r91
A hot 6 volt battery, new-large battery cables, and a starter that has been serviced -- and my 100 on 6-volt will start as fast as my 200 which was converted to 12 volts. The trick was to have the starter serviced with new bushings & bendix
