Re: F-12 Oil Pressure
Posted by Ron W on May 12, 2011 at 09:08:44 from (216.11.184.78):
In Reply to: Re: F-12 Oil Pressure posted by Dave Allgire on May 11, 2011 at 06:30:27:
My rebuild F-12 gives 80psi cold; 40 hot; 20 hot at slow idle 400rpms. I have had f12's that at full trottle 20psi cold, and nearly none at idle. In some cases it is a stuck or clogged oil pressure relief system, whil others the tractor was just plain worn out. I have one tractor that had 30psi cold; 5 hot, and when I rebuilt it O found nearly .015 in the mains.
