Re: 350 U (The Tractor Vet)
Posted by IH fan on May 12, 2011 at 10:58:52 from (99.91.9.192):
In Reply to: 350 U (The Tractor Vet) posted by JLE on May 10, 2011 at 22:10:02:
Does not seem t be any rhyme nor reason to which ones use fuel and which are economical. Dad had a '50 C that he could use all day on way less than a tank of gas. Got a Super C and it would use a tank and a half for not that much increase in power (this was cultivating corn or beans). We had a JD 60 at the same time as the SC and they used the same amount of fuel per hour for 1 1/2+ times the work on the JD (2x14 vs. 3x14 plow w/JD going a little faster) and the SC used more fuel plowing.
This post was edited by IH fan at 10:59:18 05/12/11.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
