There is a sort of flat place on the bell housing just behind the oil pan. Use that to place a jack. Remove the two bolts that holds the tie rods to the front bolster. Remove the bolts holding the wide front to the front frame. Remove the wheels from the cast center, three bolts per wheel (If your narrow front does not come with wheels) and attach the wheels to the narrow front. 4 bolts are needed to attach the narrow front to the front bolster. If you have all the parts it takes about 30 to 40 minutes with a ratchet, less if you have an air wrench. Be careful using an air wrench to remove bolts that have been in place for some time. I prefer to use a pull handle or ratchet to break them loose.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
