Re: Farmall regular?????
Posted by Bob Kerr on May 12, 2011 at 19:38:49 from (66.244.110.23):
In Reply to: Farmall regular????? posted by Al47 on May 12, 2011 at 18:49:33:
Did you know there is a line machined around the inside of the bowl of the carb? That is the float setting the factory used when assembling carbs. Try that and see how it works. Some of the kits listed the wrong float settings also.
