Re: HELP! 826 Hydro tranny trouble!
Posted by pete 23 on May 12, 2011 at 20:21:55 from (74.44.100.190):
In Reply to: HELP! 826 Hydro tranny trouble! posted by Centaur nut on May 12, 2011 at 17:56:42:
I say you have servo cyl problems internally. Might be a broken line, or leaky cyl or just low servo pressures caused by the servo relief valve. Actually I would cap the two fittings to the lines going to control valve and see if it still acts the same. Note, you will have no foot-n-inch valve at all then either. I can understand the S-R (speed ratio) lever moving by itself if you have servo problems but don't connect that to no foot n inch control that is why I say cap the lines to isolate internal from external problems and then work from there.
