Re: ta trouble
Posted by Andrew Z on May 13, 2011 at 05:16:23 from (72.10.122.33):
In Reply to: ta trouble posted by farmall 450 on May 12, 2011 at 22:01:09:
You need to split the tractor in 3 sections, to isolate the TA section. Becareful though the sections are very heavy. As for the TA its self you are better off getting a re-maned one, they run around 600-700. There is a dry clutch in the front of the TA as well that also should be examined for wear, if any signs replace. You really need a good manual with a step by step break down of the sections. I was able to do my 450 TA with the I&T manual but i had preivious knowledge of these as well. One of the most important parts when doing this is that you need a good flat surface, ie concrete floor. If you have a dirt drive or uneven surfaces it will nearly be impossible to realign the sections.
Andrew
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
