Re: 706 engines
Posted by Randy22 on May 13, 2011 at 09:00:33 from (24.248.193.103):
In Reply to: Re: 706 engines posted by CNKS on May 12, 2011 at 18:27:58:
But you've never had to explain why the engine you just rebuilt melted down. You can admit you screwed up the timing or the carb setting and fork out the money to cover your screw up or you can blame the owner and stick him with the bill.
Unless you disregard chemical engineering coupled with physics and accept tractorvet's version.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
