Re: 44 H with disc brakes?
Posted by CNKS on May 13, 2011 at 18:34:12 from (216.144.104.128):
In Reply to: Re: 44 H with disc brakes? posted by sflem849 on May 13, 2011 at 17:22:38:
I haven't used one, but I am leery of tilt beds. However, if you had the tractor on straight, at least you had more room for error than the ramps the semi had. Although I suppose yours could turn over backwards. At least the tractors didn't turn over on us.
