Re: H in trouble
Posted by Michael Soldan on May 13, 2011 at 21:20:24 from (24.235.36.122):
In Reply to: H in trouble posted by Eric Allen on May 13, 2011 at 18:14:38:
My experience with H's is that the carb is probably gummed up and the float could be sticking from sitting and having the gas in the carb dry out,leaving it gummy. Get some carburator clean and spray it in the throat of the carb with the tractor running, the higher the RPM's the better.
In the case of valves sticking ad a can of risolone,or even duralube and let the engine run ,work it a bit if you can and sticking valves usually let loose. You can always remove the valve cover and watch for movement of the valves,like others say,do some diagnostics before throwing parts at it.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
