Re: HELP! 826 Hydro tranny trouble!
Posted by Owen Aaland on May 14, 2011 at 00:32:11 from (216.47.32.42):
In Reply to: HELP! 826 Hydro tranny trouble! posted by Centaur nut on May 12, 2011 at 17:56:42:
Since you have it in the shop you can raise the rear until the wheels are off the ground and do the troubleshooting in there. Be sure it is securely supported and that the wheels are free to turn.
With the lines capped off the the tractor should operate as normal with the exception of the Foot-N-inch valve being inoperative. The S-R lever will still control the servos but the side to side movement will no longer put the hydro in neutral if it is in center of the cross slot. If the tractor works with the lines capped the problem is in the exterior controls. If you still have problems the trouble is internal.
