Posted by Tom Fleming on May 14, 2011 at 05:16:14 from (67.20.243.240):
In Reply to: H in trouble posted by Eric Allen on May 13, 2011 at 18:14:38:
some basics.
1.) makes sure all ignition components are in good working order. Plugs, wires, points, condensor, rotor, and cap. No corrosion, good connections. I realize that you don't want to waste money, but there are no shortcuts here. Clean it shiny clean or replace it. 15 years of sitting WILL take it's toll.
2.) Take valve cover off, and either start it or turn it over by hand. are all valves operating and do they have full travel. Even if a valve is moving, it needs to have full travel and close completely.
3.) Check fuel delivery. Clean out carb, sediment bowl, and lines. New fresh gasoline is an absolute MUST.
After all this, if you still have issues, post back and we will go from there.
ps. if you find a stuck or sticky valve, apply your favorite penetrating oil FROM THE TOP. Also, you can use a heat gun or propane soldering torch to heat up the valve guide. Alternate heat and penetrating oil. Moderate to light raps with a brass hammer can start to break a stuck valve loose, BUT DON'T OVERDO it. For a really badly stuck valve, you will have to remove the head. It also helps if you can keep it running long enough to heat up the head before you start this, it will really help. running the engine with the valve cover off is not a big deal for this procedure.
This post was edited by Tom Fleming at 05:40:51 05/14/11.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
