Re: Farmall H siezed
Posted by p on July 31, 2000 at 14:40:45 from (12.33.190.5):
In Reply to: Farmall H siezed posted by Greg on July 31, 2000 at 13:45:35:
a little pulling it wouldn't hurt in my opinion, but be careful. For the most part it sounds like you have a motor rebuild in order. I would pull the head off and see what damage there is. Even though these tractors sit with covers and the exhaust closed off, there is alway at least one valve open and all that it takes is a little mosture from the air to get into it. It will rust it up good. I would suggest trying to pull it reverse gear but forward as well as first gear. This will cause the piston to move in both directions. Although I have been known to try these methods with some success, I DO NOT RECOMMEND IT to everyone. EXTREME caution should be excersied. When you are dragging a stuck motor you are most likely exerting all the forces onto one specific part of the motor, specifically a piston. If you go too far it is possible to crack a piston, or bend a rod. That is alot more expensive than a head gasket. So act like you are playing with fire when dragging it, because you are! What I DO RECOMMEND is you lift one tire off the ground and put the tractor in the highest gear. then every day or couple of times a day,you can rock the tire in both directions with as much force as you can exert without outside forces. This should help free up a motor that is not so stuck that it doesn't need to come apart. If this doesn't work, PULL IT APART!! sorry to ramble but I would hate to have you write back asking where to find another motor.... By the way did you pull the plugs? you are not hydraulicing it with all the fluids in the cylinders are you...did the plugs have rust on them....
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
