Re: Super C engine problem
Posted by Tom Fleming on May 14, 2011 at 05:54:03 from (67.20.243.240):
In Reply to: Super C engine problem posted by montidale on May 14, 2011 at 05:26:43:
O-rings on the sleeves, head gasket, cracked head, cracked block. Less likely, cracked/broken sleeve. If you pressure tested it with the pan off, that eliminates O-rings and sleeves. When you pressure tested it was the block warm or cold? If you replaced the head gasket AND torqued it correctly, that eliminates that.
cracked block or head is the next stop.
