Re: conn rod bolts
Posted by gary7764 on May 14, 2011 at 06:04:57 from (98.231.24.255):
In Reply to: Re: conn rod bolts posted by F-Dean on May 14, 2011 at 05:46:26:
Don't know will find out what size this bolt is and let you know.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
