Re: Farmall A front gear case leak
Posted by mkirsch on May 14, 2011 at 06:10:19 from (67.253.161.186):
In Reply to: Farmall A front gear case leak posted by dale0268 on May 14, 2011 at 05:55:47:
The oil could be coming from one of two places:
1. The rear engine seal.
2. The transmission input shaft seal.
You'll have to split the tractor to find out which it is and replace it. Both can be replaced without tearing into the engine or transmission, but you will want to separate the torque tube from the transmission for easiest access to the transmission input.
