Re: Super C engine problem
Posted by gene bender on May 14, 2011 at 09:45:26 from (207.177.56.53):
In Reply to: Super C engine problem posted by montidale on May 14, 2011 at 05:26:43:
If you drop the pan and let it set for a day or so you will see drops at the bottom of one or more sleeves this means the rubber o-rings are letting coolant by. If you want to wait until mowing season is over you can drain the coolant and replace with 10wt oil so leaking antifreeze in the pan wont ba a problem.
