Re: Torque Amplifier (TA) Inspection, what have I found?
Posted by Farmallhjcr on May 14, 2011 at 10:31:11 from (173.44.82.136):
In Reply to: Torque Amplifier (TA) Inspection, what have I found? posted by farmallhjcr on May 07, 2011 at 18:35:41:
Began putting together a parts list:
360215R94 - Pressure Plate Assembly (is this the entire "clutch cover assembly #35" as described as in the shop manual????)
375701R91 - 7" Disc "Driven Plate #39)
359895R3 - T/A Clutch Carrier #47 (can you reuse the locking washer #46 and nut #45 that are in there if they are not in bad shape???)
832065 - Throwout Release Bearing (not an IH parts # but this is what I was told rides on the release fork, can anyone identify this # as being correct???)
364432R91 - Coupler Sleeve Cylinder (this what I can tell rides on the T/A clutch shaft and is moved by the throwout release bearing to push on the clutch cover assembly/pressure plate????)
Can anyone verify if this parts list is correct for replacing the T/A clutch components from the Clutch Carrier forward????
Does this cover all the parts in front of the
