Posted by horsepoor on May 14, 2011 at 12:06:56 from (208.124.126.217):
Hydraulics on the Farmall 240 are getting too hot. I recently had a problem with the teledepth valve sticking and causing the pump seal to blow out. Puts the hydraulic fluid into the crankcase. Pump has been repaired, and I replaced the teledepth valve body with a hydratouch valve. The way it is set up now, there are two hydratouch valve bodies on the left side of center, and a block with no fittings then another hydratouch valve with remotes on the right side. I assume that I am not getting enough flow to keep it cool, or running too high of pressure. Any thoughts?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
