Re: H live hydraulic
Posted by Janicholson on May 14, 2011 at 17:39:33 from (74.93.0.174):
In Reply to: H live hydraulic posted by David G on May 14, 2011 at 15:57:48:
THe bolt pattern on the housing surface for the Hydraulic pump mount has differently spaced holes. The top hole is at least 1/2 bolt hole out of place for the pump. Fit up the pump and you will clearly see the difference. If the pump fits either, the front cover was changed to a newer casting, or the engine is newer than the rest of the tractor. Jim -- From San Francisco,CA
