I use a center driven fast hitch mower, 6 foot, on my Farmall 100 with the shaft running at an angle to the mower. I also use an over riding clutch on the shaft. The only problem I have is I have to be careful not to lift the mower too high.will hit on the fast hitch linkage. I think that the shaft length would be critical for your situation. Over riding clutch is mounted on the pto shaft on the tractor...keeps mower from pushing the tractor when you disengage the clutch. Good luck
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
