Posted by wayne in mn on May 14, 2011 at 20:55:57 from (66.188.166.65):
In Reply to: carb H posted by Byron Smith on May 14, 2011 at 19:06:33:
Type in Farmall H and look for the carb parts diagram. High speed fuel adjustment is on the bottom; low speed air adjustment is at an angle on the upper section, and the idle rpm screw is next to the governor tube.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
