Ya you can run it with no problems that is why it has a set of U-joints in the PTO shaft so it can be run straight behind or off set. Any time you turn the U joints take care of things so no problem. Ya you might want to hook it up So the shaft sits straight behind the PTO shaft but other then that go for it and be careful
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
