Re: Dumb question
Posted by old on May 14, 2011 at 21:44:11 from (209.86.226.40):
In Reply to: Dumb question posted by notjustair on May 14, 2011 at 19:26:17:
Do this and it will loosen up fast and also may help you save in the long run. Pour about a 1/4 cup of ATF in each cylinder and let it sit a couple days. Then use it and if you want to help it even more put a quart of ATF in 3 gal of gas. Doing the ATF in the cylinders will free up the sticking rings and the ATF in the gas will free up any sticking valves
