The cups don't travel down below the surface of the head. They are there to provide even pressure on the top of the valves since they do not use a standard push rod setup.
The cups/valves get pushed down about .75-1" when the lever is pushed.
If you pop the valve cover you can see all of this stuff right there in front of you. You can then pull/push the decompression lever and see how it is functioning and compare it to how it should function. You could also take a look at the parts diagram (go to the CNH website and navigate from there) The diagram may help you see how everything in there works. I never fully comprehended everything that happened to go from gas to diesel until I took my valve cover/head off and watched it all happen.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
