Re: H live hydraulic
Posted by Reggie Palmer on May 15, 2011 at 11:01:13 from (24.107.215.55):
In Reply to: H live hydraulic posted by David G on May 14, 2011 at 15:57:48:
It's been almost 25 years since I did the same thing to my 1949 H ser. #301962. This was neccesary after the pump began leaking through the bolt holes that I (as a seventeen year old mechanic) had egg-shaped and reamed out enough to bolt onto the original front cover. (it worked for 3 years before I needed to learn the right way) I had no trouble finding the correct front cover but The big problem was finding the intermediate plate that goes between the block and the front cover. I don't know if you will need to change that on a 1950 H but I just wanted to mention that it has a nut welded to the plate. That was the one that was so far out of alignment on mine that caused all of the trouble. You are probably already aware of this, but I just thought I would mention it.
Goodluck
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
