Posted by pete 23 on May 15, 2011 at 11:05:40 from (74.44.100.190):
In Reply to: 460 Fuel Sending Unit posted by gearheadbill on May 15, 2011 at 10:54:45:
You mean original equipment type gauge , right. Same as 560, don't know why you can't find one at CASEIH. The sending unit has to match the gauge as one mfg uses a sending unit with increased resistance when reading full, and the other is decreased resistance when full. Hook sender up to gauge before installing, provide a good ground also and check your readings to see if it is correct. I just put in gauge and senders on 460 and a 656 and they were opposites of each other. In fact, I used the old sender out of the 656( that some one had Jury rigged for a seperately mounted gauge) and put it in the 460. The 460 shows full with key off, 656 shows empty with key off. Both read correctly for position of sender.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
