Posted by farmallhal on May 15, 2011 at 18:32:03 from (71.50.23.206):
In Reply to: TRACTOR WIRING posted by GARRY feldmann on May 15, 2011 at 17:34:25:
Garry, I was at the same stress point on my first tractor wiring job and Bob M who posts on this forum "spoon fed" when necessary but this isn't like trying to walk on the moon. I would suggest a couple of things, one of which is to find Bob M's wiring diagrams (some PC expert will probably post a direct link for you) on this forum for your tractor. And as noted by Harold Evans in his post the type of alternator you have will make a difference. Another thing which I did being inexperienced in the task was to only do one wire at a time and follow the diagram to a T. The wire harnesses I bought had every terminal labeled as to where it was to be attached which was a big help. Whoever you obtain your wire harnesses from will probably include some sort of diagram for installing them and they may use different colored wires which will be your clue as to installation. I would study the wire diagrams very closely before starting and ask questions before installing if you have a question. I would certainly not cut any wire thinking something was wrong before contacting where your harnesses were obtained for clarification. Good luck and a tractor is fairly simple to wire. We wish you the best and come back when you have more questions, Hal.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
