Re: pto/hydraulic pump shaft
Posted by pete 23 on May 15, 2011 at 19:42:41 from (74.44.100.190):
In Reply to: pto/hydraulic pump shaft posted by metalmender11 on May 15, 2011 at 15:05:53:
First of all, you loosen but not take off the nut up front,(it is the driver of hydraulic pump). It is right hand threaded. With all other shafts out it is difficult to lock shaft to do this but can be done. Then you remove snap ring behind rear bearing, drive bearing off shaft to the rear. Then take front nut off, push shaft back and tilt assembly up and out.
