Re: M Farmall 3-Point Lift Capacity
Posted by Nebraska Kirk on May 15, 2011 at 20:56:01 from (207.91.4.158):
In Reply to: M Farmall 3-Point Lift Capacity posted by Central Illinois on May 14, 2011 at 22:35:29:
By installing cylinders with twice the bore size as the old cylinders you have quadrupled the lifting capacity, so even if the pump was worn out and only putting out 1/4 of it's original pressure, it would still lift the bale. You could of used 3" cylinders and it still would have worked I bet.
