Re: two 6 volts to two 12 volts
Posted by rustred on May 16, 2011 at 08:30:19 from (74.200.18.155):
In Reply to: two 6 volts to two 12 volts posted by Larry M on May 16, 2011 at 07:48:12:
for sure, pos.to pos. (parallel)
if it starts good i would not even worry about 2 12's, just put in a good 12 volt with about 900-1000 cranking amps and your set .
had 1 12 volt in 560 for years now and no problem.
