IH B414 TRACTOR - PTO LEVER BROKEN
Posted by kena61 on May 16, 2011 at 12:47:20 from (216.174.129.53):
I cant engage the pto on my b414 international tractor. seems the pin(located inside the housing under the seat) that holds the lever in place, and/or engages the pto, has broken or fallen out - it wasnt in there as i was able to pull the lever right out of its slot, and at the other end of the cylinder(opposite end of the lever handle) where a pin should be(or something like that to hold it in place), there was just a hole. Any idea of how to go about fixing this problem? is it an easy fix or something i should bring to a mechanic?
