Re: 1951 super c stills smokes
Posted by rustred on May 16, 2011 at 20:58:28 from (74.200.18.155):
In Reply to: Re: 1951 super c stills smokes posted by oldiron29 on May 16, 2011 at 18:28:43:
only at the very top or bottom, in other words not in the wear section of cyl.
for example if you fitted a ring to the worn section at the top of cyl. and had a sleeve with a lot of wear then the ring can cause scoring or break when at operating temp due to expansion as it travels down in the less worn area. sleeves wear in a taper, wider at top than bottom.
but in these cases sleeve should be replaced or bored. but thats the reason.
