i cant follow this explanation. basically rings need to fit snuggly in ring groove with very minimal side clearance, and proper end gap in cyl. if the ring is able to move up and down in groove then the piston groove is worn out and the piston is junk. put together this way the rings will break , score the cyl, and total the piston. the top ring groove always wears the most. i hope yours are as explaned cause if you have ring groove spaces then may as well tear her down again.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
