I would recommend against two 12V in parallel, unless you're willing to replace BOTH batteries at the same time, every time. One goes bad, replace BOTH.
In parallel the two batteries need to be the same so they charge and discharge evenly. If you put a weak old battery together with a strong new battery, when the old battery goes bad you don't notice it right away. This causes the new battery to get overcharged due to the old battery not wanting to accept a charge. This also causes the new battery to get drawn down while the tractor sits because it keeps trying to charge the old weak battery.
What happens then is a vicious circle of replacing one battery, then the other, then the first one again, then the other again, and so on... One battery keeps ruining the other in turn.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
