Re: Glow plug is stuck
Posted by rustred on May 17, 2011 at 06:47:00 from (74.200.18.155):
In Reply to: Glow plug is stuck posted by Larry M on May 17, 2011 at 05:34:54:
i have taken some pretty tight ones out but used a 6 point deep socket. if the head is that bad that a 6 point dont work then clamp a good vise grip on it and try. worst senario is it will break off flush. then the fun begins. from here it may be machine shop work if your not comfortable with a drill and tap. but as you say simplist is just replace the injector with another good one if available.i wouldnt use heat or do welding especially with the guts still in it.
