Re: Glow plug is stuck
Posted by Ted in NE on May 17, 2011 at 06:58:13 from (74.85.105.18):
In Reply to: Re: Glow plug is stuck posted by Nebraska Cowman on May 17, 2011 at 06:26:38:
Before you twist it off. Remove the injector, screw out the center line fitting. Keep everything clean,remove the nozzle valve & gaskets. Note order they came out. Put the body in a vise and heat lengthwise along the side where the glow plug is to dull red. Will a screw right out. Clean bore good & put neversieze on the new glo plug. If you have already twisted it off weld a nut to it so you can get it out. Have done many fo them this way. Get new gaskets for to put it back togather.
