Posted by Red Dave on May 17, 2011 at 07:26:05 from (66.216.141.163):
In Reply to: external resistor posted by Henryv111111 on May 17, 2011 at 06:47:05:
Yes, but only when the points are closed. And that is an ideal voltage, your real world voltage may be off a volt or so one way or the other, but it is not critical to be exact.
When the points are open, the resistor should read 12 volts to ground on both sides of it.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
