Posted by Indiana Ken on May 17, 2011 at 07:25:09 from (66.249.229.38):
In Reply to: external resistor posted by Henryv111111 on May 17, 2011 at 06:47:05:
The voltage drop across a resistor is a function of current (amperes) and is given by: Voltage Drop = I x R where I is in amperes and R is the resistance value of the resistor in ohms. For example, if the resistance value is 2 ohms and the current is 3 amperes the voltage drop acros the resistor will be 6 volts (2 x 3 = 6). In this case for a 12 V battery, the battery side of the resistor to ground will measure 12 volts and the load side of the resistor to ground will measure 6 volts.
This is the down side of using resistors to change voltage levels - it only works when the current is constant and does not change.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
