Re: external resistor
Posted by old on May 17, 2011 at 09:41:34 from (209.86.226.40):
In Reply to: external resistor posted by Henryv111111 on May 17, 2011 at 06:47:05:
Yes and no. It depends on if the circuit is open or closed as in in an ignition system if the points are open you will see 12 volts on both sides. If the points are closed you will see 12 volts on one side and 6 on the other side give or take a little bit
