Re: 706G fuel gauge
Posted by John T on May 17, 2011 at 10:36:31 from (173.243.189.183):
In Reply to: 706G fuel gauge posted by MattSillinois on May 17, 2011 at 08:25:35:
Not sure but if its like most older standard gauges temporarily ground out the wire that goes from the gauge to the sender in the tank and if that causes the gauge needle to full deflect THEN THE SENDER IS THE PROBLEM ORRR the wires open from gauge to sender ORRR the tank or sender isnt well grounded. Use a jumper wire to insure the sender has a good ground, some get their ground from the tanks sheet metal and it may not be well grounded, others may have their own ground wire.
If when you ground the senders little terminal where the wire down from gauge is attached the gauge full deflects, the gauge (and its input voltage) and wiring are both okay, so its either the sender is bad or theres a bad ground.
Also insure when the tractor is switched on theres hot batetry voltage getting to the input (NOT to sender) side of the gauge as it cant work unless voltage is applied to its input.
Finally if theres voltage on the gauges input and when you ground the output (just momentarily touch to it dont hold it on a long time) the needle dont move, its a gauge problem.
Often Ive seen gauges where the needle is just mechanically corroded and stuck.
For a gauge to be good there needs to be continuity from its input to output, if it reads an open circuit its bad.
Get it????????? If I missed anything or those gauges are differnt then I described, Im sure the other fine gents can add to this.
John T
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
