Re: Adding Hydraulic Remotes
Posted by mkirsch on May 17, 2011 at 14:10:07 from (64.80.110.75):
In Reply to: Adding Hydraulic Remotes posted by Mark Albers on May 17, 2011 at 10:23:35:
Unless the Fast Hitch control valve has been replaced, it is a Tel-A-Depth type, which means you move the lever to the relative position where you want the hitch to be and leave it there.
It won't work like a normal remote, so you can't tap into it and get anything useful.
A lot simpler than tapping, is to get a set of extensions to run from the bucket remote to the rear. Unhook the bucket and hook up the extensions.
That's how we did it.
