Re: cub pto shifter
Posted by Bill Lisbon on May 17, 2011 at 17:54:57 from (69.89.163.252):
In Reply to: cub pto shifter posted by swany on May 17, 2011 at 13:47:01:
It could be the coupler that the shifter moves is worn,or the shaft is worn, I have seen this a lot on Cub's with rotary mowers. Aftermaket parts are available, $100 to $150 depending on where you get them.
