Re: cub pto shifter
Posted by gene on May 17, 2011 at 18:53:01 from (66.43.40.73):
In Reply to: cub pto shifter posted by swany on May 17, 2011 at 13:47:01:
Not a difficult or a major task.
You need to purchase the shift lever along with the coupling because the lug on the side of the shift lever that moves the coupling wears out.
Remove the filler plug on top of the differential and use a flashlight to line up the parts during assembly.
