Great progress. Personally Id say use the clutch on the left, with the springs and what not, as it appears to be in better shape than the other. Also if you haven't already check for alot of wobble/slop on the front gear that drives the PTO, I had to replace the bushing in it on my F12 because it was so bad. Just to be certain there is no water you may want to loosen or crack the transmission drain plug to let any water run out if you haven't already as all the water sits in the bottom since the oil is thicker.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
