one side of the meter is to ground, as a reference,..the other side .
lets assume a simple ignition ckt. 12v baqt, ign switch, 1 resistor, and the coil, pionts,, etc.
with points open, you get bat volts on both sides of the resistor and both sides of the coil..
with points closed you get bat volts on the sweitch side of the resistor, and some less volts on the other side of the resistor / input side to the coil, and ov course no volts on the points side of the coil
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
